ANTI-LOCK BRAKE SYSTEM WARNING LIGHT DOES NOT ILLUMINATE ON DASHBOARD
MY ANTI-LOCK BRAKE SYSTEM WARNING LIGHT DOES NOT ILLUMINATE ON THE DASHBOARD
WHAT COULD BE THE  CAUSE OF THIS ?
Has it just stopped or never worked whilst you’ve had car. Most likely reason is that it has ABS fault and light has been deliberately broken to try to hide the fault
If it has just started happening during your ownership then it must be a blown bulb/wiring issue as if there was a fault it would illuminate all the time.
