TDCI 55 plate. Air in the fuel lines, again!
Hi all 😊 Hope you're all staying safe and enjoying this weather!
While the weather is this nice, thought it would be an ideal time to investigate where the air is getting in, into the fuel lines.
As of November 2019, I had injector seals replaced and as of June 2017, had fuel pipes, primer and pressure sensor replaced. I also replaced the fuel filter, atleast 2 years ago (the bolt that holds it in place is no longer in as the thread in the plastic housing as threaded away I believe)
The air is getting in through this pipe (see image) when I had the air box off.
Any ideas what could cause this?
Forgot to mention. Sprayed the fuel lines, primer and line connections with leak detector and couldn't find anything.
