  1. Tap the 3-dot menu (â‹®) in the top-right corner of the browser.
Ranger 53 Crankshaft pulley
Hi Guys
I am trying to remove the Crankshaft pulley bolt,I can not move it even with a large breaker bar.
Is there a special tool for the job or is it just brute force
Thank you for any answers or help in advance
Regards
Clive
sorry  guys should be in ranger forum
I am not telling you to do this in case it ends in damage or injury but I have done this. Disconnect spark plugs so engine won’t start when stArter motor used. Put a    Ring spanner on crAnkshaft bolt. Wedge end of ring spanner against something that won’t move (body work, ground etc) . Turn key to engage starter motor momentarily. This should turn engine so bolt undoes. Check your engine rotated clockwise when running . At you own risk. I do not know what chance there is of something else breaking, eg starter motor. Ring gear. Spanner.  AT YOUR OWN RISK
5 hours ago, 154WHU said:
Hi Guys
Regards
Clive
I use a length of hollow scaffolding bar to increase the length of my long breaker bar for situations like that.
