Replaced dpf pressure sensor
Hi there am just after some advice the local garage replaced my dpf pressure sensor and 2 pipes off it is it rite that read that they need programming as when he put it on he said it had a electrical problem so put the old 1 back on and I get a low pressure warning code
DPF pressure sensors need their learned values resetting when fitting a new one, they can't be programmed as such.
