Installing ambient footwell lights Mk4
I've got ambient footwell lights from Autobeam that I want to hardwire into the interior lights so that they come on when the car is unlocked or doors are opened. Should this be easy to do? I've tried taking off the trim at the front passenger side but not sure which wires are for interior lights. Has anyone else tried this or something similar with footwell lights for the mk4?
You could try wiring them directly to the ceiling lights, the side trim up the edge of the windscreen comes off really easily, you may be able to wiggle a wire through to the ceiling light and tap into the bulb wiring from there.
Or you can do a fuse tap to the fuse it uses.
Thanks, will give that a try.
I did think about a fuse tap but from looking at the manual I can't work out which fuse is for the interior lights.
  • 1 year later...
Having the same issue did you find which fuse to use?
