low mileage high age should I think about replacing the timing belt?
Hi, my 2009 1.8 Zetec only has 32,000 miles but its 11 years old. I really don't want to put any more money in the thing after buying 3 new tyres but should I maybe think about changing the belt next year or am I good for awhile do you think?
Petrol or diesel?  The 1.8 petrol has a chain rather than a belt.  The 1.8 diesel has 2 belts and I would recommend doing them asap at that age.
It's a petrol
2 minutes ago, gloves said:
It's a petrol
Good choice - no timing belt to worry about!  There is no interval for the timing chain, it should last the life of the vehicle. :smile:
Personally I'd have a visual check of the aux belt (the one that runs alternator etc) and replace that if it's cracked or perished.
so that's probably the belt I've seen, it looked a bit dirty. I'll have to inspect it a bit further.
Many thanks, sorry I know bugger all about cars 😞
No worries, that's what the forum's here for!
For future reference, the timing belt is almost always covered so you'd never see it.  The auxiliary belt (aka drivebelt, accessory belt, alternator belt, fan belt) is the one you can see that runs the alternator and air con pump.  They only cost about £20 and are super easy to change so very different to a timing belt.
The timing belt is covered and hidden for a good reason.
If it is exposed, then in sub zero conditions with blowing powdered snow the small flakes of snow will build up on the toothed side of the belt to the extent that the belt is lifted off the toothed pulleys and either breaks or comes off.
Thankfully it's not much of a problem here in the UK.
ScaniaPBman.
Nice theory, but it's not really the reason why they have covers lol.
The cover is simply there to stop road debris getting caught in the belt.
a number of factors put stress on the cam drive of any engine (belt or chain)
bad design, tensioning or material (not an issue on the ford)
age, UV & other factors makes material degrade (its called nature)
contamination adds up with age (fluids, like antifreeze, pas, engine oil, dirt, debris, road filth)
wild cam shaft lobes (not an issue on these)
lots of short jorneys with lots of starter motor abuse (cams are exceptionally hard to rotate from off and very easy once running - so a taxi gets 200 k and your gran get 30k)
Start Stop (a new feature together with a weaker overall design for the cam drive - designed to sell cars and help fiddle the manu's co2 targets - has nothing to do with the environment and makes it dangerous in cut and thrust driving conditions - can and should be permanently turned of with FORscan)
the fun element - of course people should change cam belts - 600 quid and the car has another 100k and that's the problem - a good belt is £20.  But you need a kit with the tensioner and pulley's, plus the PAS and alternator stretch belt, then you should do the water pump because it will let go 10 mins after doing a one time only belt swap.  Whilst the system is empty you need to do the thermostat coz its easy then and a night mare any other time... whilst doing the job you disturb the design to fail PAS pipes and that's another £110
  • 3 years later...
I am thinking of buying a 2013 ford fiesta, does this have a timing belt that will need changing? Thanks in advance
Hi Sarah,
We can't give a definite answer without knowing which engine it is. Virtually all engines have a timing belt which requires changing at some time, the interval and cost varies.
Assuming it's the 1.0 ecoboost, it should have been changed at 10 years so you will need check it has been done, and if not factor that into your purchasing decision.
Thankyou, yes it is the eco boost & hasn’t had it changed so may not be so much a bargain as originally thought.
Expect to pay £1100 to £1800 to have the wet belts replaced. My concern would be it is already living on borrowed time and how has it been previously serviced.
No, there loads of independents that charge much less than this, a place up in Barnsley does them at £950 all in.
That reminds me - did you ever get any further with the guy up in the North East we spotted advertising wet belt changes on (I think) Ebay?
No, is the short answer.
I was trying to put a poster here on the forum who lived only a short distance from them in touch.
As what often happens the OP disappeared and failed to return 🙄
TSC Vehicle Solutions in Barnsley, very good reputation locally. Ex Ford technician does them at £950 all in, very friendly guy as well always happy to give advice.
Interesting. From his website https://www.tdciservices.co.uk/ you'd think he only did 1.8 Tdcis but I see he has a Facebook page and an Ebay ad also: https://www.ebay.co.uk/itm/115826451088.
I’ve spoken to him personally, does loads of 1.0 Ecoboosts. Reckons once the belt is done they are invariably ok so long as it’s not started knocking but sense would tell you to stop driving when the oil pressure warning came up. He does say that using the Castrol stuff is essential however.
