Footwell lights
Hey all, I recently bought a mk 7.5 fiesta st3 and from what I've seen a lot of these models have the red footwell lights, however mine unfortunately don't illuminate.
Do the illuminated footwell lights come as standard on this model or should I be having this booked back in with the dealership to be looked at?
I could be the fuse,the handbook will tell you where it is.
Check your lamps before starting anything else..
Check if they have bulbs in and that the bulb hasn’t blown.
you would need 501 fitment red LEDs.
Blimey, I haven't seen footwear with lights in since the 90s!  I'm sure plenty of us had those trainers with soles that lit up as you walked... :biggrin:
Autocorrect is a pain in the ***** 😂
So I have a white led that lights up when I open the door and the footwell illuminates, as soon as I close the door and start the engine it goes off 😞
6 hours ago, Stoney871 said:
Edired title
May want to edit your "edired" post 😂😂
So they’re working correctly then, just need to swap to red LED lamps.
