Mk6 st cluster and indicator not working
Hello to you all i need help with this problem, I have a st and the right indicator light  on the cluster is stuck on and the other side dose not work. Also no ticking sound but all work out side of the car.  I have tried another gem module still the same, checked all bulbs and  fuses. The car has had a full st conversion by last owner so I have a facelift fiesta with a pre facelift running gear and dash cluster ect just thought I'd mention it in case it helps. Really need some help to this problem so I can m o t the car.
Electrical faults can be hard to detect. Can be from blown bulbs,loose plugs, corrosion, bad earth, faulty relays and switches. just got to persevere and check all.
