Fault please help P0304 / P0304 P
My daughters ford fiesta 1.2 (2014) has had this engine light fault light
I have done research on the fault and most people recommend  changing
Spark plugs , changing spark plug leads , and changing coil pack which I
Have done , but after resetting fault light after about 10 to 15 miles the light comes
Back on , I have checked as   I can the fuel injectors  by listening to injectors by using
Long screw driver and all injectors are clicking pretty good ,,, so I am now lost for next
Plan , any help would be much appreciated …..
You could swap over two of the injectors to see if the fault moves to another cylinder.
yes i think i will have to do that , its strange because it seems to run great no misfire, no loss of power !
cheers for help
from what i have read, that fault code is a misfire on cylinder 4, you can try swapping the injector to see if that helps, also that all the spark plug boot is properly seated on both the plug and the coil
No I have not checked intake pipe but I will . If I can find it lol cheers
Yes I will have to swap the injectors over , only problem my daughter works in London , and comes home at weekend, so that’s the only time I can work on it !
