Re-fitting rear drum
How do I get the fiesta rear drum back on when the adjuster is backed right off
have you pushed the brake shoes back together it will give you some more room 😊
Yep all pushed back, it seems to be the hydraulic cylinder holding them open, is jthis possible?
Squeeze the pistons together with waterpump pliers if that's the issue.
Usually they're just out of alignment and need a tap in the right direction though.
Thanks will give it a try
They were the wrong shoes supplied
glad you got it sorted 👍
