MAF VS MAP
Can I use a maf sensor in place of a map sensor? I need something circular so I can use my cold air intake but can't find any round MAP sensors
no you can't due to the way they read, MAF reads the air flow of the intake, MAP reads the absolute pressure of the intake, unless you are changing the ECU as well they aren't interchangable due to the values the ECU is expecting
Thankyou. I have decided to get some 3 inch hose and stretch it over my map sensor since its oval. Then have a 3" to 2 for turbo
