Help Sony head unit
Ok picked up a Sony head unit with the ‘colour’ screen for my 7.5 (this is non sat nav screen)
I previously had the all blue screen with BT
1st problem- doing a station scan it seems I can only find 2 FM stations(Radio 1 and BBC Radio Kent) - but 1-4 is preprogrammed with BBC 1-4 and they work but I was looking to add some local station - am I doing something wrong?
2 -it’s Dab - no dab but I presume I need to enable this via forscan ( my car has both aerials connected)
3 when I open the door instead to leave I get  kind of ‘ blurred’ squares (should this be the Ford logo-do I need change the display via for scan
im pleased but really like to sort theses few issues out
thanks in advance
See my topic I made a couple years ago. Couple posts down i show the forscan option. Hopefully doing this may fix your other issues.
Thanks Luke I’ve followed that
just awaiting a new battery before I plug in forscan- when I did it Saturday it detected mine was low so thighs I’d better get a new one
If you are doing any changes with FORScan you are best to have a charger connected to your battery.
Is that necessary even with a new battery ?Its arrived today
Ok thanks for the help
update
have enabled the Dab and get a great reception
im unable to cure the screen above - going into ‘Touchscreen’ settings
I have changed it from 3 (something ) 4 something colour screen but it still shows the blurred screen on shut down and start up
any thoughts would be greatly appreciated
im sure someone must have done this before - the error just seems to be with the start up / close down splash screen
The error your on about looks like this picture? This looks like the normal screen to me, I've seen it on quite a few cars when the radio is off etc.
As long as the radio functions as expected and the screen works fine when turned on, i wouldn't worry about it.
that great thanks
well looks like it all good then
wondering if I should revert the screen to what it was before MFD3 I think
can I enable cruise before I fit the steering wheel( I’m holding off this hoping a friend can help as it’s not something I’m looking forward to)
