Brake rotars
What's the best way to clean rust rotars and calipers hot sopy water or brake cleaner
How rusty are they? If its only a little bit of surface rust then it will go away the first time you use the brakes.
Anything more then just replace the disc, they're not expensive and a whole lot easier than trying to remove rust and keep the surface perfectly flat.
