Flasher relay
Can somebody please tell me where the flasher relay is located please, a pic would help immensely. Having major indicator issues and want to try everything before thinking it's the BCM. Already tried swapping bulbs, swapping light clusters etc but still the indicator is stuck on static
It's part of the BCM.
Ahhh so I need a new one?
Have you checked the existing one for any signs of damp or corrosion?
Is it both sides or just one?
It's just the near side bulb that stays on static, if I disconnect the bulb then all bulbs work, when connected, that bulb stays lit and the mirror bulb doesn't work
Front or rear?  That sounds more like an earth issue than a BCM/relay issue to me.
It's the front near side that stays on static unless I disconnect the bulb, hope it's as simple as that to be honest
