Wash wipe not working
My 15 plate Fiesta S wash wipe has stopped working, both front and back. Can't hear any sound from the pump and wipers don't move, although they do work on normal wipe function. Fuses are ok and I have tried a new stalk. As far as I can tell there is no relay for that circuit.
Am I missing something obvious or could it be something more complex.
Many thanks
Sounds like the body control module at fault. Unplug it and check for corroded pins on connectors and bcm. Could even be a glitch with the bcm. Disconnect battery for a few mins and refit. Check washers and wipers.
Thanks iantt. Is the bcm the unit behind the glove box with the fuses?
Yes, It is the fuse box behind the glovebox.
