Cylinder 3 Low Compression
Got low compression on cylinder 3 on 1.25 petrol, 2014.
Mechanic done a compression leak and no air was escaping so either dodgy valve/lifters or piston ring. My concern is why this would happen on a ford serviced engine and only done 54k miles.
The hydraulic cups are easy to push down compared to the others.
Has anyone changed these and have a tried and tested method and is it a common issue on these engines?
