Strange Smell when under load
Hi Everyone
New here. I've just got a Ford Transit Courier 2016 35000 miles which I believe is based on the Fiesta.
A couple of times I've noticed when I pull up a steep gradient especially in reverse, I get a horrible smell from the ventilation.
At first it smelt like burning leaves, this morning like burning cabbage!
It's really wierd.
Apart from that it runs fine.
Any ideas?
Clutch slipping I would guess. I get the same if I reverse up a steep gradient in the Fiesta without fully releasing the clutch. Just release the clutch fully when going up steep hills (unless of course this isn’t the problem and I’m just lecturing you but I’m 99% certain). If it doesn’t happen when motoring normally, this would be the most likely option.
Hey thanks for that. I do tend to release the clutch very slowly scared of stalling it. I'll release it fully and try using my right foot a bit more!
It doesn't happen when motoring normally it pulls really well. It's just from a standing start I get the problem.
Just sounds like you are riding the clutch a bit too much from a stand still
Thanks for they help. I've only had it a short while I'm getting used to it slowly.
Anyone know about warning lights? Just this morning the Spanner and the Oil Can lights came on.
I've checked the oil level and it's OK. Can you get the error codes by holding in the pedals and turning on the ignition like you can with the Vauxhall's?
Gramthy
Oil light might come on if the oil pump is failing so oil pressure is down.    I'd say get a cheap ODBC cable and forscan and try and read some codes.
No...that resets the service reminder on Fords lol.
However, oil and spanner light is the service reminder...so remember that sequence if you do your own servicing. :biggrin:
Been doing some research and it seems it is not a warning about Low Oil Pressure but a service reminder light is that correct?
Yes, that's correct.
Thanks for the help.
I've reset it by holding down the Brake and Accelerator pedal while turning igintion to II.
It's just been serviced so I assume they forgot to change it.
