Disable folding power mirrors
Hello all,
The motorised power folding mirrors on my girlfriend's Fusion are worn an produce an awful clicking noise. I'm assuming this is because the plastic gears inside have become worn over time. It looks like the only way to fix this is to replace the entire unit.
Is there a way I can disable the folding mirror feature for the time being so that she can still remote lock it? A fuse I can remove, perhaps?
Cheers.
look at the fuse panel id card and see if there is a fuse for them i suppose ?
only problem i imagine is that if there is there may be on a supply that is linked to something else possibly.
There is a way to disable them easily.  I believe you fold the mirrors in manually then lock the car and manually unfold them again.  Then the auto-fold on lock/unlock should stop.  That might not be the right sequence but it should be in the handbook.
