2007 Ford Focus mk2 water leak
Hi
i have a Ford Focus MK2 2007. I have a water coming into my car & I am stumped where from. The front right side of my boot carpet is soaking wet, the rear right seat is also soaking up water. I’ve replaced the boot seal & I have taken the boot apart & sealed absolutely everything I can to stop it. I have no idea as to where it could be coming from, there are no obvious water trails in the car to suggest where it could be coming from either. Can anyone help with a possible solution? Thanks
1 hour ago, Jmunn said:
Hi
Have you tried seals around the rear lamps what about door rubbers
Yes, I’ve tried all the seals. There’s no obvious place it’s coming from as I can’t find any wet trails or spots in the car whatsoever. I’ve taken the whole boot apart & there is absolutely no sign of water getting in from anywhere. The boot floor is wet at the top right & that is all
Hi
Have you checked the seals on the rear spoiler ? They are known to leak on the mk2.
The leak on mine was from the screws that secure the rear lights.
I haven’t. I will check that next. Thank you
