heated front and rear switch not working
Can anyone help with my problem please, the switch that turns my Ford Fiesta front and rear heated screens stopped working, I checked the fuses under the bonnet all ok, then a few days later they started working again but the lights on the front and rear switch have stopped working again any ideas ?
Bummer mate! I am don't know much about electrics, but do you here a click when you press the button for either of them? I think the click comes from the relay. If you changed the fuses but still don't work and you don't here a click when you turn them on, might be the relay.
have you removed the panel, it sounds like a loose connection
Does both front and rear heated screens run off the same relay
looking at the fuse diagram it would appear so (in the engine bay fuse box)
Problem solved battery not holding full charge fitted new battery everything’s working, thanks
