Dome Light
so I changed my interior dome light to an LED bulb and now the light only works if I hold the button & plastic cover in a certain position. Ive tried changing the bulb back to the original one and it has the same problem. Any ideas???? thanks
Take it back out, on the back of the rocker switch there are 2 brass prongs, you might need to bend them slight so they are in contact with the brass contacts inside the fitting, once you have it apart you will see what I mean.
