2010 mk7 Fiesta remove ignition barrel
Hi there, am currently replacing the upper steering column/motor and the ignition barrel won't out. (The column/motor is already out if that makes a difference)
Have put key in to 1 and the top pin pushes down but the barrel doesn't pull out, there is no other pin below it or on the underside.
Any help before I take a grinder to it? Thanks
