Leak
⁸Hi, just signed up to get some help
Ive got a 2008 fusion, just noticed the water was empty so filled with coolant, went for a spin to let it warm up and its leaking from underneath, i cant see any obvious pipe leaks but can hear a slight hissing from the coolant tank slightly.
1226103038_Screenshot_20210221-164229_VideoPlayer.thumb.jpg.990467ce680134b68d5ecccca9bd4342.jpg
Ive filmed it but its too big to upload
By the way i barely know what im doing so anything too tricky it will have to go to a garage but hoping i can save my self a few quid
We have a 2007 Fiesta and a 2010 Fusion, and I have replaced header tanks on both.  They were both showing stress marks and bulges.  It might be the cap, but tank is cheap and easy to change.
  • 2 months later...
Might well be worth checking the water pipes under the fuel filter. On the diesels they do have a habit of cracking. Did my one as a preventative measure.
https://www.ebay.co.uk/itm/RADIATOR-WATER-MANIFOLD-INTAKE-HOSE-PIPE-FOR-FORD-FUSION-FIESTA-MKV-1-4-TDCi-/333310962788#vi-ilComp
The only water leak that I've had on my diesel Fusion is the thermostat housing, it's plastic and prone to warping but I believe it's been modified now so once it's been replaced it shouldn't need doing again. I couldn't see the leak but I could smell the antifreeze coming up from the back of the engine.
I guess after 2 months his car has now ran out of coolant and the leak has stopped.
