Ford Fiesta 2014 Headlight Swap
Hello!
I want to change my standard reflector headlights with projector and DRL LED ones.
As I saw on the physical connector of the headlights, the standard hl connector has 10 pins and the one with DRL led has 9 pins (pin 6 is missing). In electrical diagrams, pin 6 is used for Parking light.
Do you know if the headlights are plug&play and what should be changed exactly in Forescan/IDS or another programming tool to work properly?
Thank you!
