lack of boost
Hi guys just a quick one. I've got a 1.0 ecoboost and Friday night I was driving normally, was doing about 50mph when all of a sudden when letting off the accelerator and proceeding to accelerate again, the induction kit started making a much louder whooshing noise, and I found that the car has seemed to lose power since then. I eventually pulled over and removed the primary induction hose to check the turbo's turbine and it was fine and the air filter seemed to be on correctly. So does anyone know what this could be? It sounds like air is escaping from the system somewhere and isn't building up the correct amount of pressure. Or maybe there's a sensor unplugged somewhere? Im convinced its a vacuum leak of some sort, and it's worth mentioning that i have recently replaced the turbo. Any ideas would be helpful, thanks
check your charge pipes (the pipes leading from the output of the compressor on the turbo to the intercooler, to the intake manifold)
Had the same problem last night lost all power, loud hissing when foot to the floor and spanner light came on, turned out to be the silicone pipe connecting to the turbo hard pipe, jubilee clip failed
