Mk8 1.0 Ecoboost idle RPM
Hello to all ,
I was wondering if any one can tell me what is his idle RPM after the engine has warmed up ? I’m suspecting mine to be a bit high indicating a minor vacuum leak , would be interesting if the check is done through the hidden menu to be more accurate 🙂 thanks in advance 😊
Hi Ahmad,
If it's of any help - just had my first MOT test. In the emissions test the "natural idle speed" was recorded as 954rpm - exactly as per your shot above.
On 3/3/2021 at 12:20 AM, Eric Bloodaxe said:
Hi Ahmad,
thank you very much , then this is the normal idle RPM , I thought I have a problem , its a bit high anyway, may be due to the engine being a 3 cylinder , thank you very much for considering 🙂
