  1. Tap the 3-dot menu (â‹®) in the top-right corner of the browser.
Conrod bolt torque settings
Hi, just ordered new bearings and conrod bolts for MK7.5 ST180.
I just need the torque specs for the bolts, I have tried asking ford themselves but they said they could not give them to me, hoping someone here has the correct torque specs before I go ahead and put them in.
Thanks 🙂
Ford dealers are right. There is no info on fords workshop manuals . Doesn't specify any engine block dismantling.
Ford considers the bottom end to be unserviceable. Both technical information or internal parts of the bottom end are not available from ford.
These bolts are TTY (Torque To Yield) and require a very specific torque and angle. The manufacturer or seller of the bolts should specify the recommended torque / angle values.
I get the following warning message:
CAUTION: Measurement of bearing clearance is not possible by normal methods and should not be attempted, as this will result in damage to the cylinder block and crankshaft. If bearing bolts have been loosened the entire cylinder block and crankshaft must be replaced.
