TPMS help
I need help - one of my TPMS sensors was damaged so I purchased a set of 4 from eBay (£30)
Had it replaced but the car would not learn the sensor using a snap on tool - sensor not detected
So I purchased another single sensor from eBay - sold as genuine Ford £17
Just had that fitted today - same scenario- no detected- check tyre pressure
so far I’m down about £100 for a sensor that’s driving me crazy
Its a 2015 fiesta zetec
 any advice or help would be appreciated before I push it off a cliff
Was hoping someone would come to my rescue with a solution
You need to put the vehicle in training mode to learn the sensors. Here's the procedure, one it's in training mode you need to start with the left front tyre and go around the car clockwise finishing with the left rear. The horn will beep with a message saying training complete.
Programming
NOTE: Enter Training Mode Without Scan Tool
NOTE: The horn will sound once and the TPMS indicator will flash if the training mode has been entered successfully. If equipped, the message center will display TRAIN Left Front (LF) TIRE.
With the ignition OFF, press and release the brake pedal.
Using the start/stop switch, position the ignition from OFF to RUN 3 times, ending in the RUN position.
Press and release the brake pedal.
Position the ignition to OFF position.
Programming
Thanks for the reply
I did try this with the snap on tool but when it gets to the drivers rear - no sensor detected - this is the 2nd sensor I’ve had fitted with the same results
this is the sensor I’ve fitted this time
Hmmmm, I would ring up your local Ford parts store and ask what engineering part number they have for TPMS sensors for your car and see if it matches, there are a few variations floating around now and your car may only be compatible with one of them.
Ok thanks
Ok thanks
my local deal would not give me a part number
What's your reg I'll look it up at work tomorrow
PM’d cheers
I have 4 of these but they can’t be detected
Can they be ‘stimulated’ off the car
