Engine does not crank
Engine cut out now won’t turn over when pressing start button had new battery fitted and new batteries in key fob scanner code says low fuel pump pressure could this cause the engine not to turn over ?
  • 5 months later...
Had intermittent starting problem a couple of months go. Had new starter motor  and battery fitted, still had problem. Turned out to be a sticking throttle. Replaced, now fine. Good luck.
