Battery?
Stupid question time,if there's no instrument lights at all on the dashboard is it a flat battery? Also the key fob wouldn't open the door I had to open it via the key lock
that sounds like either a flat battery or the master battery fuse has blown
Or the comms has gone ***** up. I'm assuming you don't have a multimeter to check battery volts? Quick check - disconnect battery for 10 mins and see if it all comes back to life when reconnected. If not, most probably duff battery.
Thanks for advise guys......
It was the battery
