Fuel Filter Problem?
I'm looking for some help/advise on an ongoing problem I have.  My Fiesta Zetec (2007) has been having issues with random stalls at junctions (This has pretty much stopped since and removed and cleaned the throttle body) and very slow acceleration going up to 70mph.  Also it idles erratically.  I've researched my symptoms and it appears the most likely cause is a fuel filter issue.
Please can you tell me where the fuel filter is located and if it a difficult job to do myself.  I am by no means a mechanic but I've had some experience repairing/replacing parts.
Thanks in advance.
J.
I've heard elsewhere that it is just in front of the fuel tank which is towards the back on the passenger side.  Does this sound about right?
Thanks.
J.
Thanks.
J.
Yes, its there. Easy to reach by laying at the passenger side of the vehicle.
Pull the filter to unclip it and you press the quick release tabs in to release the pipes.
If you can raise the passenger side slightly it makes it much easier to see and get 2 hands at it.
Being a pressurised fuel line you should remove fuse 15 and start the engine until it stalls to release the pressure.
Thanks for the reply Dan,  do you think that this is an easy enough fix for a novice?
Safety is important, don't do it unless the vehicle is on level ground off street, you don't want anyone bumping into the car while you're working underneath.
If you don't have an axel stand use blocks of wood and also the spare wheel underneath the vehicle to ensure that there is no chance the vehicle can fall on you. Keep the jack in place too.
The first time I changed mine I used my brothers pit but it really wasn't necessary.
This video shows exactly what you need to do apart from releasing the fuel pressure first.
Thank you for the video link Dan.  It seems straightforward enough.  How do you release the fuel pressure and do I have to pressurize the fuel afterwards too?
Thanks for your time.  I appreciate you helping me out.
J.
Just follow the instructions that Dan has posted above
Yeah, I'll do that. I've ordered the filter. Thanks.
Just an update.  My new filter came on Wednesday and I have literally just replaced it.  I took it out for a quick spin and it seems to have regained its power and is back up and running.  I followed your advice Dan and the video link and it was a simple straightforward fix.
Thanks for your help.  Appreciate it.
J.
