Removing Fiesta steering column to grease shaft
Fiesta 1.25 2004.
I am trying to remove the lower end of the steering column shaft so I can grease the shaft as I am getting a slight knock at very low speed.
I have removed the lower 10 mm bolt and I thought I should then be able to swivel the universal joint hook out of the way, but it seems very resistant to moving. I have tried prising with a screwdriver and also tap gently with a hammer but it doesn't move.
Am I missing something obvious?
Thanks.
Have you tried blasting the hell out of it with spray grease ? Turning the steering as you blast at it.
Best to get some old clothes you'll never wear to cover up the carpet, wipe off excess grease when stopped dribbling & set.
Thanks for the suggestion.  So keep everything in situ, rather than undo it, and spray grease down the shaft?
TBH, I am not actually convinced the slight knock is coming from there anyway but thought I would try the simplest, cheapest option first, as it seems many owners have reported this issue and it often it has been fixed by greasing this shaft.
