Towbar electrics
Hi all need help got a towbar electrics to do on my Ford mondeo 12 plate titanium hatchback, I have run the wire in to the boot and found the wires I need to wire up the the 7-Pin Universal (Bypass) Wiring Kit  it's the black box that the wire from towbar goes to and the other wires goes to the car wiring and has a 12v wire to it, but I have rear led lights can it be still wired up the same, I hope some one can help please, thank you
The wiring will be exactly the same. Are the LED lights on the rear of the car or on the trailer/caravan being towed?
Rear or the car as my car is the facelift one thank you
Since its a universal kit and not connecting to the BCM of the car, just wire the kit as if you had standard lights.
Thank you much appreciated,
my hubby can't understand that when you press the break pedal on or off it has a constant 12v running through the led lights thank you
