Ford Dealer Charged Me For A TSB Fix?
Hi Guys,
I was recently made aware of a TSB fix that Ford had published in regards to the common rattling noise issue around the engine heating area (relating to faulty O rings).
The Technical service bulletin is No.19-2378 (see TSB document attached)
I have Ford Protect extended warranty on my vehicle but the dealer said the warranty doesn't cover O rings.
£114 for Diagnostic Check
£120 for Faulty O rings Replacement
Total £234
WTH? I feel like I have been stabbed in the back by Ford
FordEtis - TECHNICAL SERVICE BULLETIN  19-2378.pdf
A TSB is supposed to help the dealer to find and fix a problem. It saves the dealer time in diagnosing the problem and trying to invent their own fix, when a fix has already been found.
It is not a safety recall or an indication that the fault would be covered by a warranty. The dealer is perfectly entitled to charge you to fix the problem if your warranty doesn't cover it.
Give Ford Customer Service a call and state your case. I guess you could argue that the original design has an issue that causes the noise, hence why there is a TSB to fix the annoying noise. So your car had a design issue for which their is a known fix.
The dealer that has carried out the work needs to be paid one way or another. If you argue your case well, and you have a full dealer service history then that relationship may allow you to recoup some / all costs from Ford UK
As always you guys provide excellent advice.
I will firstly try to get a response from Ford Protect but if they fail to resolve the issue will contact Ford Cuatomer Services
That TSB is to fit 2 O rings not to replace any, did they replace some O rings on yours? If so it may have had the TSB done with a previous owner or on a service visit, if the O rings were worn, then by the wording in the warranty T&Cs the dealer is probably right.
