Upgrading to Active Cruise Control
On 8/6/2024 at 2:35 PM, Stan89 said:
Hi all
i got the problem cause I’m active my Acc and is working with no problem on my old switch, but when I’m change the switch to the for Acc I get messages wrong component, acc work with no problem but I can’t change distance, I’m program the sccm module but still is new button not working. Please can someone help me
I’m having the exact same problem as you. Did you ever figure out how to get the switch working?
  • Replies 52
  • Views 32.1k
  • Daddy Nev
    Daddy Nev
    Update. ACC is now fully functional. Issue was a communication protocol issue when talking to the PCM. BIG thanks to the Forscan team for making a custom version for this PCM.   When I
  • For Wesow, The ACC will work on UK Edge's as long as you have anti-collision system fitted as standard. So does the heads-up light up on the dash if you get too close to another vehicle? If yes,
  • Daddy Nev
    Daddy Nev
    This is not a simple task. Converting to ACC is no Saturday afternoon job. The entire process took me a whole day in the end, but that was after spending hours and hours trying to resolve a hidden ECU
I can't remember, sorry.
It may be BCMii
May be IPC,
Just go into each module until you see the option
@DaveT70 no worries, thank you. I’ll see if I can find anywhere in the modules for a part number to be entered
