Headlight LED upgrade
Hey guys I need some pls! I have a Ford Mondeo Mk4 2012. I’ve brought the Osram Led H7 headlights upgrade. They work fine but I’ve now got an low beam bulb fault on the display. Is this something to do with the resistance which is causing the problem? Do I need an 60ohm Canbus error code canceller ?
You probably need a canbus decoder/resistor/canceller.  Although it is actually weird to have the fault displayed since you are using OSRAM upgrade.
