Tlbd fault
My car went in to limp mode so I turned it off an it won't start now has  T1bd fault
What do you mean by it won't start? As in it wont crank? Does the ignition even come on? If so then you should be able to retrieve the fault code.
as Luke says more info needed. Could be battery and alternator failure, and then again without DTC's it could be anything
He said its not the cam shaft sensor an said its the belt as it had teeth missing, it trys to start but won't was driving down the road engine malfunction came up so turned it off now won't start but says cam shaft sensor has the belt had missing teeth he said its that what do I do, he also said it might have a safe engine in Other words my engine could be safe not blown
Battery fine
Belt was on but missing teeth dose try to start but won't go?
Basically said he thinks it bust but I don't think so need help guy an how to find out if engines gone
Right this is a little different from what you described 😂.
If the cambelt is missing teeth the engine won't run until you replace the best. Chances are it's also damaged a few valves inside the engine so will need the head re-building.
i'm not being funny but what on earth is this supposed to mean?
Your "in other words" didn't really clarify anything other than write the exact same thing 😂.
 Most diesels are interference engines, so if the timing jumps then you do some serious damage.
How can u tell if the timing belts gone?
You just said that the timing belt has teeth missing.
The timing belt is ## %&£@ Broken!
