Reverse camera issues
Hi
Would any one be able to shed any light on whether this is a dodgy connection or a camera fault please.
https://youtu.be/0hXcjjq61F0
It didn't work at all the other day when I parked at work. When I came out later it worked fine so it's hard for me to work out what it might be.
A dodgy connection is likely to be a permanent fault, or a flicker under movement as it struggles to 'connect'. As your fault appears when stationary, I would suggest that your camera may be failing. My reverse camera (although totally different) started off with a flickering error, before over a few weeks developing into a permanent 'no picture on screen' fault...
Thanks @StephenFord
Weirdly enough I went out in it after posting, when I got to my destination it had the same problem, when I got home and pulled on to the drive the problem had gone again.
I agree with your statement, and will start looking for cameras. I bet they're expensive 😞
