Global window closing...........Did anyone get it to work.
I have a 2011 Titanium and would like to know if this can be added or activated and even my old 2008 corsa had this as standard and only the basic model.
If it’s mentioned in the owners manual as a feature,  you should be able to program it using Forscan.
other than testing it worked on mine when I got it, I’ve never used it.
I think it depends on whether you have one touch up and down. The global close wouldn't be very safe without it incase someone puts their finger inside and you walk away.
It should be active. Press unlock and release, then press and hold unlock and it should work, same procedure with locking.
I have tried pressing and holding the lock on the key fob and didnt work,i know my drivers side have one touch but pass don't.
Its not a major thing if not but i have a few times left the window down beeing so hot and got out locked car then having to put key in ignition and put it up.
Just was seeing if it can be done.
Did you try pressing, releasing and then pressing and holding within a couple of seconds?
You have to have one touch on both windows & if a 5dr then has to have front & rear power windows.
I do have all electric windows all round and only drivers is one touch,its a shame there isnt a way but there you go.
There is the problem- you need one touch on all the windows.
I have one touch on all windows (3 door) all working but it doesn’t work for me
