Intermittent jolting/juddering on Transit courier
Hi, I’m new to the forum.
for the last 4 months I’ve had an intermittent problem with my van jolting when I press the accelerator. It only happens when the van is up to temperature and seems to coincide with me driving it a bit harder through the Rev range. There’s a very slight delay when you hit the throttle then a jolt and then it accelerates smoothly. Whenever the fault occurs it’s accompanied with the engine fan being on. There also seems to be a slight judder when you come off the accelerator.  When I turn the van off and on again the fault disappears and there is no juddering or jolting whatsoever. Van drives perfect t again. It’s a 2020 plate 1.5 tdci 100bhp with 2300 miles. Ford planning on dropping the gearbox to check DMF as I finally got it to fault for them. There are no fault codes. Thanks in advance.
So I meant to ask, has anybody experienced this or have any ideas what the problem could be? Thanks
  • 1 year later...
Hi Steve, I have a very similar problem on new courier, 06/22. Going in to dealer for 2nd time next month. Previous courier did no have any problems.
  • 3 months later...
Did you both find out what was causing this problem mine does exactly the same?
  • 1 month later...
Hi I have a 2019 courier sport and I have the same problem as you,did you find out what the problem is
cheers Wayne
There is a bit of a theme going here. Ask the question and never post the answer. Keep asking the same questions and still don't get an answer.
So @wayne1575 i very much doubt you will get answer, but you could be the first to come back when you find out and let everyone know how you fixed it 🤔
