I have hesitation in first gear
Hi I have hesitation in first gear when taking off I have to tap the gas pedal a few times to pick up speed its ok in other gears just first gear is really awful the idle is fine never cuts out I've told its the EGR valve so any info would be much appreciated on how to solve this problem thanks.
Hi Mike, I kind of think you have answered your own question. Problem is most likely the EGR valve as you yourself have said.
So replace the EGR valve and see if the problem goes away.
Since I don't know the exact engine you have I can't say what part number you need but a quick look on eBay shows most models are covered. For example:-
https://www.ebay.co.uk/itm/393414849398?fits=Car+Make%3AFord|Model%3AGalaxy&hash=item5b995a3376:g:3zkAAOSwDqlgsqd-
Thanks unofix for the reply I was hoping it wasn't the EGR valve lol cause its a pain in the ***** to get too in my car 2.2 durotorq TDCi its right at the back apparently but I'll give it go thanks again. would be best to replace the complete EGR valve or just clean it not sure???.
I used to have a 51 plate Galaxy 2.3 Ghia which I loved dearly. Kept it for 10 years and only once had a problem with it, which was the A/C compressor failed.
I have a 58 plate Galaxy 2.2 Ghia and I love it people are saying to get a blocking plate for the egr valve because its a problem with these cars I don't know was wondering if you know Unofix? but yeah lovely cars.
I wouldn't block the EGR valve off, it can in the long term lead to other issues. They are not really a problem remember that the one fitted now has lasted over 12 years so if say the replacment only lasted 6 years would that be a big problem ?
