Fiesta 2006 1.4tdci Expansion tank
I had the head gasket replaced on my car then after a couple of weeks the coolant was blowing out the expansion tank they redone the gasket again and replaced the tank and cap. Is it normal for the coolant to be always running in the top pipe on the tank as it it sounds like you can hear it when you acellarate fast?
The head gasket doesn't just fail, there must've been a reason for it going in the first place. Have they sorted that issue out?
Did they also skim the head and check the block with feeler gauges and a straight edge?
Yes the head was skimmed and had all new gaskets cam belt kit water pump and thermostat housing.
