headlamp aim projected beam image is obviously incorrect
HI all
I have recently bought Ford Mondeo Ghia 2.0 and brought for MOT and failed with some major Advisory included  both side headlamp aim projected beam image is obviously incorrect.
the previous owner have installed white LED bulb (low beam)
need advise how to adjust on correct aim (as per UK requirement)
Thank you in advance 🙂
You might need to just fit some regular halogens, the headlamps are designed to project the correct pattern based on where the filament would be. That's why aftermarket LEDs are always marked for "off-road" use.
@Super Mod oh ok , noted I will try that
Thank you 🙂
