Led bulbs
Has any one out ther know if you need a specialist relay for led indicators as I have fitted them and the are flashing like I have bulb out .
Also it come up on the screen as a warning but all are working just to fast help wood be appreciated
Your car has a Canbus system that has detected the LED bulbs and it doesn't like them. Fitting a suitable series resistor might work but  if the car is not made for them LED bulbs are rarely plug and play.
Hi Matty, you need to fit a ballast resistor across the LED to create a load equal to that of the original lamp.
Just do a search on eBay for LED ballast resistor and find one that matches your original bulb
Thanks very much
I'll have a look for one tomorrow
Similar thing happened on my Merc, went out to it the next day and it had 'learnt' I had LEDs 🤷‍♂️ very peculiar.
You could use the Phillips silver turn signal lamps, they are not LED but they get rid of the fried egg look.
I have a pal called Andy, he owns https://www.facebook.com/hnasupplies/ and his LED lamps will be straight plug and play, they have built in canbus resistors. I can personally vouch for them, as can many members of my Mk5 Mondeo FB group.
Cheers
