DTC Chart and pinpoint tests ( official Ford manual )
Hello to all,
Attached are two official documents from Ford, one is a DTC chart for trouble code descriptions and possible causes, under each trouble code you will find a direction to a relative "PinPoint" test, which consequently you will find it in the other document, with step by step guidance with yes and no procedure.
just thought this could be of any help 🙂
DTC Chart.pdf PinPoint tests.pdf
  • 1 year later...
hi guys i have a 2006 ford focus zx3 a/c compressor dont work when it hot with cool days works fine and after a short run compressor cuts off and only warm air a\c is fully charged
Well you won't ever have that problem in London, when was it last hot ?
  • 2 years later...
Just wanted to thank Ahmad1986 for the DTC Chart and PinPoint test... priceless.
I've tried to find the similar info for the BCM but no success.
Any chance you have info on that or can direct where I'd find it?
Much appreciated.
