Air Bag Light Flashing 4-2
Hi all, 2003 1.4tdi Fusion
The air bag light has started flashing four times then two times before staying on.
Can anyone help please?
Thanks a lot.
You need to read the DTC's
Use the software FORScan: https://forscan.org/download.html
You will need an ELM327 lead: https://tunnelrat-electronics.fwscart.com/USB_Modified_with_switch_ELM327/p4541936_17045457.aspx
Read the DTC's and post them here and someone will be able to help
Many thanks for the answer, I will investigate that and post the results.
Can you tell me where the front crash sensor is located in case I need to change it? 2003 Fusion. Thanks
Fusion front crash sensor
Many thanks
