No Drive
I have no drive after fitting a new concentric thrushbearing. I have a clutch pedal after bleeding the clutch. I have removed both drive shafts and they look ok. I have put it into gear and started the engine and there is no rotation in the diferential. This was the original problem that  happened to the car hence changing CTB. I will be removing the gearbox again to check the pressure plate and spinner plate but all looked in order with no signs of any damage to it when I originally removed the gear box. I never removed the  pressure plate though. Ideas please. Thanks
Ok here is the result of no drive on the Ford Galaxy. I have removed the gear box , pressure plate and spinner plate. The fault is a faulty spinner plate. No visual signs of damage placed it on the gearbox splined shaft and rotate out of gear spinner plate appears to be fine. However once I put it into gear and there is slight resistance by the gear box the spinner plate rotates around but NOT in the centre on the splines the centre of the spinner plate remains still but the outet spinner plate rotates on its access. Product failure as I fitted this 8 months ago. I have never had this fault and have replaced many clutches before.
