Mk7 Fiesta 1.6 TDCI heater always blowing hot even when on cold setting!
Hi all, hope this doesn't sound too stupid...
I've noticed with my fiesta now the colder weather is coming in that once the car has warmed up it is constantly blowing hot air, even when its on 16 degrees. It feels like it's on the hottest heating temp on any setting unless i put it on LO then it will blow cold air, but as soon as I change it back to 16-17 it will start getting hot again...
It was looked at by my garage a while back and he said there was nothing to worry about but never explained why it does it?
Can someone explain this to me if this is normal or is it worth getting a second opinion elsewhere?
Thanks in Advance 🙂
It may be the heater resistor, if these go bad then the controller for the heat setting will not affect the temp of the air. Might be worth looking at some Scotty Kilmer videos as he has done  few on this topic .
hope this helps 🙂
hope this helps 🙂
Thank you! will have a look!
