---HELP--- Retrofit reverse camera of Ford Focus Mk3.5 2015
Hi to everyone,
I have replaced successfully the harness/loom with part no. F1ET-14D466-AAE and the camera with part no.  H1BT-19G490-AE (to the gray plug) to my Ford Focus 2015.
After the installation of the above loom and camera I have programming the modules as the below:
sn%C3%ADmek-obrazovky-2021-04-02-v%C2%A019-42-31-jpg.389947
The camera is working properly when I put the reverse gear but the static lines of green, yellow, red  and also the dynamic white line does not exist in the display neither in the camera settings.
Moreover I am getting an DTC error of BCMii U0264 - Lost Communication With Camera Module- Rear  but the camera is working normally on reverse of course without the lines features as said above.
I have tried to run the service of BCMii Local Interconnected network New Module Calibration and at 12% get that error "Service procedure has been interrupted.
I am thinking that the specific camera module that I have installed with part no. H1BT-19G490-AE is not fully compatible with my Ford focus 2015.
Every help will be appreciate!!🙂
I take it you have gone into the APIM and BCMii AS BUILT modules to make the hex code changes. I'd suggest looking in the APIM and BCMii modules that do not have 'AS BUILT' next to them. In those modules you should be able to select the correct parameters using a a drop down menu.
If the distance lines aren't showing though there may well be a problem with the camera itself
Try setting the BCMii module to "1" No Dynamic Lines and see if they then appear on the screen but don't move.
I fitted a reverse camera on my Mk4 Focus and I have the lines but they don't move. I think that there is a wire that has to go from the camera to the BCM for the Dynamic Lines to work.
The dynamic lines and zoom are connected to the LIN module, I'm not sure if Forscan reads the LIN however.
I would suggesteavihg it as it is and trying to run the calibrations service on the New LIN Module if you can. If that won't run then it means the loom you have does not contain the wiring to the LIN.
I have set the BCMii to 1 and the error change from BCMii to IPC U0264 - Lost Communication With Camera Module- Rear and no any other change, the camera still working normally.
The wiring loom that I have installed to my Ford focus is the F1ET-14D466-AAE.
 I have connect its 6 cable connector to the 6 cable existed grey plug so how the loom is missing the LIN wiring?
The camera that I have installed have part no. H1BT-19G490-AE which is for the Fiesta MK8 but I have bought it for the reason that i have read somewhere that is compatible with focus MK3.5 but may the specific model of camera not.
By the way guys thank you very much for the help!!
Is there a violet/white wire in the loom? That is the colour for the LIN as far as I know.
Did you see if there was a calibration service for the LIN?
I have upload some pictures of the retrofit parts to understand exactly what I have put in my car.
Also I will upload the grey existing plug and the grey connector of the loom that come from camera.
  • 4 months later...
On 10/30/2021 at 2:44 PM, GiorgosCh said:
How did you get on with this project?
  • 2 years later...
@KevG I have managed to fix the errors by replacing the camera with the camera F1ET-19G490-AC.
IMG_20240628_220140_edit_105412264297976.thumb.jpg.e44ebe68d95ccb9f6d148b7c7784769e.jpg
