  1. Tap the 3-dot menu (â‹®) in the top-right corner of the browser.
Need advice mk8 transit 350.
Hi
New here so be nice I'm flighty 🤣. Read pretty much all the Relivant posts, great reading BTW. But yes mk8 limp mode on. P2463, p246c, p2463p and p246c both pending. Did have a p2033 but it cleared. That is current status. It was at the garage recently they plugged it in found 4 faulty glow plug and loom. Replaced. Exhaust temp sensor. Replaced. Fuel filter sensor and housing fault replaced. Failed regen due to blocked dpf. It also has a battery/alternator fault. Start fine after 5 mins the battery warning comes on. Stop restart same thing. With a suspected blocked dpf removed air hose at dpf started up no big hissing in fact a gentle breeze. Finally if you switch off then on the engine warning light stays on but the info warning limp mode is off but comes straight back on. Like a challenge 🙂. Any advice greatly appreciated.
